Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
kipsmiks
Newbie
Joined: 04.Nov.2008 Location: Latvia Status: Offline Points: 3 |
Topic: New mwnu barPosted: 05.Nov.2008 at 15:04 |
Hi!
I want create new Autocad menu bar "Section" (like: File, Edit,...) Under "section" is list with beam section type HEA; HEB; UPN.... under each this section name is correct section. And I can insert in drawing this beam section as block or region. Example: Section-> HEA-> HEA300 and in draving is 2D beam sections |
Vladimir Michl
Senior Member
Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2196 |
Posted: 05.Nov.2008 at 18:47 |
You have not given your AutoCAD version but for most versions you can MENULOAD a custom .MNS file which contains something like:
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,148 seconds.
New mwnu bar
Topic Options
