RSS discussions
Discussion Discussion forum
Topic ClosedGPS Coordinates
 Post Reply Post Reply
Author
GrayChase View Drop Down
Newbie
Newbie
Using: Autocad 2019
Status: Offline
Direct Link To This Post Topic: GPS Coordinates
    Posted: 05.Feb.2019 at 23:22
I have a drawing, associated with Google Earth and GPS Coordinates. Internal coordinates are set to geographical and are correct.  I can enter individually specific points at the correct Lat. & Long. but cannot seem to get a .txt or excel (.scr) file to load properly. If a do a multiple "points" command from copy/paste, all new points are close to origin and not where they belong on the drawing. Running script command leaves no points on the drawing. I really do not want to enter 93 points individually. I feel like I must be missing something pretty basic. Any clues on how to get individual points on a drawing from a list of latitudes & longitudes ? Thanks !!
Gray
Back to Top
Newbie
Newbie
Using: Autocad 2019
Status: Offline
Direct Link To This Post Posted: 05.Feb.2019 at 23:44
Follow-Up. Just entered a point at specific GPS coordinates.  The point IS on the drawing, not close to the entered coordinates; Further, the properties box for the point does not even have the coordinates the point is on ?!?  Hope someone can tell me what I am missing !
Gray
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Posted: 06.Feb.2019 at 07:17
Hello Graychase, maybe I'm wrong but if you use AutoCAD after AutoCAD 2012 you should enter # before your coordinates to have them "absolute" and not "relative".
The same, when you move an object from a point to an other, X,Y,Z will give you relative new coordinates in relation to the initial point and #X,Y,Z will give you an absolute new coordinate, etc...
Please tell me/us if this helped or isn't correct.
Back to Top
Newbie
Newbie
Using: Autocad 2019
Status: Offline
Direct Link To This Post Posted: 07.Feb.2019 at 01:30
I'm not explaining my issue well i'm afraid.  Still checking on "what I want" vs. what I get. I'll be back !! Thank you for the response !
Gray
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,215 seconds.
