Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
RSS discussions
Discussion Discussion forum
Topic ClosedReplace block with non block object
 Post Reply Post Reply
Author
JestAs View Drop Down
Newbie
Newbie
Using: Autocad Map 3d 2022
Status: Offline
Direct Link To This Post Topic: Replace block with non block object
    Posted: 13.Oct.2021 at 13:24
Hi
I need a lisp routine to replace block with non block object.....such as closed polyline or mpolygon, and preserve block's object data table.
I know it is possible to replace block with another block and preserve original OD ("ReplaceBlock.vlx" routine, found on this forum.)
Is it possible?
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Arkance Systems CZ
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 13.Oct.2021 at 13:28
What should be the purpose of such replacement? Do you mean putting e.g. a hexagon in place of the former block reference? What is the difference to putting in a block containing a hexagon?
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 15.Oct.2021 at 22:48
What do you mean by "preserve block's object data table"?  Part of that is the mere fact that it's a Block, which it can't be any more if you replace it with a non-Block object.  Another part of that is an insertion point, which could possibly be relevant to its replacement, depending on what kind of object it is, but if it's a Polyline, the obvious entry would be for its first vertex, which may have no meaningful relationship to the Block's insertion point.  Other parts that probably will not be relevant are scale factors, rotation angle, and Block name.  So what about it do you hope to "preserve"?
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,082 seconds.
