Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
jmontesmx
Senior Member
Joined: 28.Jan.2008 Location: Mexico Using: AutoCad2017 Status: Offline Points: 115 |
Topic: QUESTION ABOUT AEC OBJECTSPosted: 18.May.2022 at 04:38 |
I really appreciate if someboy can help me with this, I have a Draw with AEC objects and I need to insert this in another draw like a block but I can't do it because all the AEC objects disappear, Only can I insert the draw like using XREF but I need insert also other draws with AEC objects the draw it grows so much. I hope somebody will have a solution to this.
Vladimir Michl
Senior Member
Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2196 |
Posted: 18.May.2022 at 05:48 |
So you have the same AutoCAD version which opens a DWG file properly (showing AEC objects - either through an Object enabler or as proxies) and doesn't open the same DWG when inserted into another DWG drawing?
I would look into the proxy setting -
PROXYSHOW.
jmontesmx
Senior Member
Posted: 18.May.2022 at 18:03 |
Exactly, that's what happens
Vladimir Michl
Senior Member
Posted: 19.May.2022 at 08:29 |
And what is the PROXYSHOW setting in that host drawing? Also consider installing/updating the Object Enabler (see Download).
jmontesmx
Senior Member
Posted: 24.May.2022 at 02:13 |
solve my problem in the following way:
a.- use the xref command
b.- load the file where the AEC objects are
c).- Once there, before closing the reference files window, right click with the mouse on the file that has just been entered, there the Bind option is selected and in this one select insert and ok.
d).- In this way the AEC objects are introduced as a block.
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,105 seconds.
Topic Options
