RSS discussions
Discussion Discussion forum
Topic Closedsee through shadeing
 Post Reply Post Reply Page  12>
Author
kjud View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: see through shadeing
    Posted: 10.Dec.2008 at 13:34
If you place the shading on a locked layer there is a transparency slider on the dashboard (2007+) which applies the transparency to everything on locked layers.
Back to Top
galea16 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Dec.2008 at 21:38
There is an easier way, depending on the plotter driver you are using. From the plotter configuration screen select graphics. There you should see (depending on you plotter) something entitled Line Merge Control. If the display order of you drawing is correct Lines Overwrite will work. If you do not wish to control you display order select lines merge. When using lines merge, lines under a screened solid hatch will show through the hatch.
Michael Galea
Back to Top
alliegaeta View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Dec.2008 at 21:16
Thanks Ron C, I would like to learn about Visual Styles and what you say, I don't have to use the shading often but even using the solid command  and send to back has made my new task possible for me (or should I say created another area of work for me)
alliegaeta
Back to Top
Ron C View Drop Down
Groupie
Groupie
Using: AutoCAD2010
Status: Offline
Direct Link To This Post Posted: 03.Dec.2008 at 17:28
You may want to check out the help section on regions.  You can create a region then assign shading to that region, then change the transparency of the shading.  You will have to also know a little about Visual Styles (Realistic) and how to plot the view port with the Visual Style.
RDC
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 30.Nov.2008 at 22:56
Right on Tobias,
gave it a demo this morning, thanks for that.
Solid, send to back, make sure colours are lightly done and bingo, done.
Much appreciated.
Alliegaeta
alliegaeta
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 30.Nov.2008 at 22:02
Thanks  but island detection would be too fiddly for these plans, there is too much to show under the shading.
I dont really want to hatch lightly
The floor plans of a 2000m2 + need to look like it has a light wash of colour over it and be broken up in a few sections
Alliegaeta
alliegaeta
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 30.Nov.2008 at 21:57
Thanks, but the floor plans are large building floor plans (2000m2 +) with a lot of items that must remain visible through the shading.
If possible I need the building floor plan to have the whole plan shaded in possibly 3 or 4 different sections, but still seeing the whole floor plan under the shading.
Hope there is an answer.
Alliegaeta
alliegaeta
Back to Top
Ringis View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 28.Nov.2008 at 14:18
Originally posted by rossassociates rossassociates wrote:
Are you hatching and then putting the text in place, or is the text in place and then you're hatching?  Our text always has a clear area around it, when we hatch an area around it (ACAD 2005)..
That depends on if you have "Island detection" on or off, and which style of "Island detection" you have ( normal, outer or ignore)
To see the "Island detection" you have too press the arrow in the lower right corner in the hatch dialog box.
//Tobias
Back to Top
rossassociates View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 28.Nov.2008 at 13:42
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 28.Nov.2008 at 11:42
I would still use Solid hatch, and after that change the draw order for the solidhatch. There´s is a toolbox cold "draw order", simply select the hatch and press the button send to back. Now everything else should be visible, but of course you should use a light/different colour then everything else.
Hopefully this help you out!
//Tobias
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,163 seconds.
