RSS discussions
Discussion Discussion forum
Topic Closedar-sand hatch
 Post Reply Post Reply
Author
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Topic: ar-sand hatch
    Posted: 10.Jul.2023 at 17:59
Hello waynelem and John, ar-sand is giving big heavy files with only dots, maybe ar-sand would do the job better.
I use very little hatching also because we nowadays use a lot small paper sizes.
Maybe PURGE will help you with your prints.
I remember now that in the early day of AutoCAD R13 ( year 1995 ) our printer hadn't enough memory and the seller of the printer came back to place more and we also learned about PURGE and so on.
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Arkance Systems CZ
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 10.Jul.2023 at 08:57
Is the hatch displayed? It can be either limited by the display settings - see:
https://www.cadforum.cz/en/autocad-will-not-create-a-specific-hatch-in-given-scale-or-area-tip11538
Or your plotter driver (or plotter) is over its memory limits.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner
Back to Top
waynelem View Drop Down
Groupie
Groupie
Using: autocad 2012 full /2014lt
Status: Offline
Direct Link To This Post Posted: 08.Jul.2023 at 21:42
Using AutoCad 2022. Windows 10.
ar-sand hatch will not print. Any ideas?
This is a big problem as I have 100's of dwgs. made in AutoCad 2014 and I need to use and they in the most part have ar-sand hatch.
wayne
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,102 seconds.
