Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
sam675
Newbie
Joined: 24.Dec.2024 Location: Qatar Using: AutoCAD 2021 Status: Offline Points: 6 |
Topic: auto block replacement lspPosted: 23.Oct.2025 at 08:49 |
uploads/977892/xch.lsp
Hello world! hi guys, i have been using these 2 lisp regularly for a while now. i was wondering would it be possible to have some sort of lisp that combines both of their function? I do apologize i cannot give credit to the owners of these lisp as i have already forgotten where i got them. the first lsp is xch, replaces the block and inherits the rotation - however, when the basepoint of the block is not in the center of the block it will mess up the location of the new block - relative to the basepoint of the original block that will be replaced. second lsp is mchange - where regardless of the basepoint or rotation, the block will be replaced as is, and i have to rotate the block manually. now ideally what i was looking for is the best of both worlds - if possible a lsp that would replace the block on the same location as mchange.lsp, but inherits the rotation of the block like xch irrelevant of the basepoint. any help would be much appreciated.
Vladimir Michl
Moderator Group
Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2196 |
Posted: 24.Oct.2025 at 08:24 |
What about the existing block replacement LISPs? See:
https://www.cadforum.cz/en/what-is-the-difference-between-the-blockreplace-breplace-replace-tip14402
julecave
Groupie
Joined: 17.Jul.2022 Location: Palestine Using: audocad 2015 Status: Offline Points: 86 |
Posted: 26.Nov.2025 at 18:28 |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,203 seconds.
Topic Options
