RSS discussions
Discussion Discussion forum
Topic ClosedBlock Question
 Post Reply Post Reply
Author
goyousalukis View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Block Question
    Posted: 19.Feb.2009 at 19:27
I have a quick question:
I have a dwg with a block in it (the title block). I need to change some of the text inside the block. The only way I know is to explode the block, edit the text and then select everything again and then make it a new block. Is this the best way? I am working in Autocad LT 2000.
Thanks,
Justin
Back to Top
nameci View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 19.Feb.2009 at 20:46
Hey goyousalukis,
Click the block and then right click, select edit block in place. Change what you need to and then save the change.
Hope that helps,
nameci
Back to Top
tkelly View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 24.Feb.2009 at 06:16
If you are using 2007 and above  version of Autocad just double click the block and it would open in block editor and then save the block again.
Or
Use "REFEDIT" command and follow the instructions.
Tom
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,083 seconds.
