RSS discussions
Discussion Discussion forum
Topic ClosedALIGN COMMAND
 Post Reply Post Reply
Author
RAHSAN View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: ALIGN COMMAND
    Posted: 01.Mar.2009 at 15:01
Why 'Align' command doesn't work in LT 2009? Are there any other way to align the objects/lines?
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 02.Mar.2009 at 18:40
You can make a Diesel macro with similar functionality (there is one in our LT Extension). Or wait for LT 2010 - it contains the ALIGN command.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Arben.Allaraj View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 02.Mar.2009 at 21:52
I have attached an  AutoLISP file and DCL.
I hope that them could help you.
uploads/20090302_215217_ALIGNIT.LSP.rar
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Back to Top
tkelly View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 04.Mar.2009 at 11:15
I am not sure if lisp files works in Autocad LT. Untill 2008 version lisps could not be loaded into lite
The way I align the object in Autocad LT is first "scale" the object to desired dimensions.
Then place the object to one of the end point of object to be aligned.
Then "Rotate" the object with reference option.
Tom
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 1,754 seconds.
