RSS discussions
Discussion Discussion forum
Topic ClosedMessy File
 Post Reply Post Reply
Author
michGIS View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Messy File
    Posted: 27.May.2009 at 18:07
I am working with AutoCAD Map 3D 2009, and have made updates to a DWG file that was originally created years ago (before my time here).  The updates are completed and now I need to print 125 layouts (previously created).  I am able to plot to PDF using DWGtoPDF.pc3, BUT once it has plotted to file, the program hangs up and due to time constraints, I shut down via the Windows task manager.  I suspect one of the issues may be caused by the Plot Style Table and/or the Plotter Configuration Files previously created, which I have tried to change.  Beyond that, my limited knowledge of AutoCAD has brought me to a stand still to be able to debug the problem.  Can anyone help?  Or make suggestions for me to investigate that I am unaware of?
Thank you!
Back to Top
msplcdykee69 View Drop Down
Senior Member
Senior Member
Using: Civil 3D, Map, Inventor, Mechanical, & Electrical
Status: Offline
Direct Link To This Post Posted: 28.May.2009 at 20:47
Have you gone into your control panel  "Autodesk plot Style Manager" and "Autodesk Plotter manager" and just deleted and replaced your pen table and plotter driver?  I have also found deleting .pc3 files help as well. always pick your plotter driver never the .pc3 files.  That is the way I get my Dwg to Pdf driver to work.
Engineering Manufacturing Medical Cables/Adjunct Instructor Engineering Graphics/Engineering Computations and Careers
msplcdykee69@yahoo.com
Shawn
Back to Top
tkelly View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 30.May.2009 at 10:48
If you are able to work in file I am not sure why you are not able to print using DWG to PDF.pc3 but I would suggest try with other PDF printer like PDF 995 or Cute PDF if it works. If it works then there is problem with PC3 file .
I would recommend not to Print 125 layouts at one go (If you are doing so) this could create problem.
Let me know what you find out.
Tom
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,156 seconds.
