RSS discussions
Discussion Discussion forum
Topic ClosedDB connect
 Post Reply Post Reply
Author
prakash_anu View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Topic: DB connect
    Posted: 09.Jun.2009 at 08:21
can Anyone tell me what is DB connect? what is use of it? how it use? suggest any tutorial link for that.
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 09.Jun.2009 at 10:20
You can use DBconnect to link your drawing entities to database records or to display database data as attributes in your drawing. Can be quite powerful when used properly.
You can find more information in AutoCAD Help.
Vladimir Michl (moderator)
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 09.Jun.2009 at 14:44
if i change in database (excel) file then it change in autocad drawing file? like excellink lips file from xanadu. that mean if i chang number of attribut it chang in autocad.
Edited by prakash_anu - 09.Jun.2009 at 14:45
Back to Top
Moderator Group
Moderator Group
Status: Offline
Direct Link To This Post Posted: 09.Jun.2009 at 16:11
Yes - you can setup it this way (you may need to issue an update/regen command).
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 15.Jun.2009 at 10:26
I have make a block with attribute with a different value 1,2 & 3 with name of chair in block now I extract data in excel format. then I each chir with dbconnect. Now I want to change the value of chair in excel & it   reflect in drawing. How can I do this? that means how i set up dwg this way?Smile
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,078 seconds.
