Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
patriot
Newbie
Joined: 13.Sep.2007 Location: United States Using: AutoCAD 2015 Status: Offline Points: 6 |
Topic: Change Text to BoldPosted: 13.Aug.2009 at 18:20 |
Thanks for your help.
theflyer84
Newbie
Joined: 13.Aug.2009 Location: Italy Status: Offline Points: 5 |
Posted: 13.Aug.2009 at 16:41 |
the only way to correctly use the texts for future changes is to use the "style" command.
type "style"... it will open up a "new world" ;) basically you can create several styles, for examples one for the dimensions, one for the titles, one for the comments, and so on. Than, with Mtext you select the appropriate style before typing... once you will need to chage the propriety of all of the texts all toghether, you will just need to type "style" and change it ![]() it is cool, but in your case, you must start all over... ![]() hope that helped for the future anyway! www.dwgforfree.com Edited by theflyer84 - 13.Aug.2009 at 16:42 |
gizmeau
Newbie
Joined: 28.Jul.2009 Location: Thailand Status: Offline Points: 6 |
Posted: 29.Jul.2009 at 05:48 |
Mtext alway cause that problem. You may need to change of your text to be Dtext. To me Dtext alway work better than Mtext when you want to change or modify thing. |
patriot
Newbie
Posted: 29.Jul.2009 at 04:50 |
AutoCAD 2006 - I have a dwg that has many text strings that I want to change to "bold" text (True Type Arial). I thought this would be no big deal...change one and then match properties for the rest. It will not match "bold"...the only way I know how to do it is open each text hi-lite each and select bold. Problem is that I have very many and that is time consuming and I may miss some. Does anyone know a fast way to change text to bold other than one at a time?
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,148 seconds.
Change Text to Bold
Topic Options
