RSS discussions
Discussion Discussion forum
Topic Closedtitle blocks
 Post Reply Post Reply
Author
debrito View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: title blocks
    Posted: 23.Aug.2009 at 23:38
hi
          well i think thats what its called!!!!!  , i want to have a template that everytime i print or plot a new drawing i am propted to change the text in the title block  ie
date , project ,title, drawnby, drawing number , revision, and so on ,i have created a block and a few layouts with viewports in and boxed off separate  sections for the text but is driving me nuts now can anyone help ??????please CryCryCry
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Arkance Systems CZ
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 24.Aug.2009 at 11:37
You can e.g. Redefine the PLOT command to insert (or modify) a block containing the required attributes. This will need a LISP routine.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 24.Aug.2009 at 17:23
hi thanks what is lisp ???Shocked
Back to Top
Arben.Allaraj View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 24.Aug.2009 at 21:31
"LISt Processing" .
So in our case we use a dialect of LISP called: AutoLISP .
For more help navigate on google about AutoLISP programms and how we use them.
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Back to Top
Bassman View Drop Down
Groupie
Groupie
Using: Autocad 2013
Status: Offline
Direct Link To This Post Posted: 16.Sep.2009 at 13:30
Hi
Ive placed an a1 sheet on the cad blocks wich has attributes attached
use the command attedit to edit the text
not quite what you are looking for
hope this helps
regards chris
Back to Top
tulip3D View Drop Down
Senior Member
Senior Member
Using: AutoCAD2011, Inventor2011
Status: Offline
Direct Link To This Post Posted: 16.Sep.2009 at 20:47
autolisp is the text command entry for old-head CAD users. These days there are icons for everything. I saw go with what Vladimir said and just create a block. Here we use blocks for everything.
Back to Top
siknit View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 17.Sep.2009 at 12:55
an other way is to refined the PLOT for doing this
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,096 seconds.
