Over 1.127.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
Marciano
Newbie
Joined: 15.Sep.2009 Location: United States Status: Offline Points: 2 |
Topic: Polylines?Posted: 15.Sep.2009 at 07:17 |
How do you join multiple lines into one solid shape that can be extruded? I scanned drawings into a raster program that converted them to .dwg's but I cant figure out how to make the shapes connect into one solid unit
I'm using Autocad 2000 Edited by Marciano - 15.Sep.2009 at 07:42 |
Pitstop
Newbie
Joined: 24.Feb.2009 Location: United Kingdom Status: Offline Points: 3 |
Posted: 15.Sep.2009 at 12:37 |
You can pedit them to join, lines together, but may find some are not closed but to the process they have come from. You could also try this lisp to join them
(defun c:JP (/ ss)
(and (setq ss (ssget ":L" '((0 . "ARC,*POLYLINE,LINE")))) (if (zerop (getvar "peditaccept")) (command "_.pedit" "_m" ss "" "_y" "_j" "" "") (command "_.pedit" "_m" ss "" "_j" "" "") ) ;_ if ) ;_ and (princ) ) ;_ defun |
Vladimir Michl
Moderator Group
Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2180 |
Posted: 15.Sep.2009 at 13:17 |
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
Marciano
Newbie
Posted: 16.Sep.2009 at 06:44 |
Thank you! PLJOIN worked, i was trying the other two commands but to no avail. Now I can extrude them and send them out to be fabricated.
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,066 seconds.
Polylines?
Topic Options
