RSS discussions
Discussion Discussion forum
Topic ClosedDRAWING TRACE.
 Post Reply Post Reply Page  12>
Author
Ferna View Drop Down
Groupie
Groupie
Using: 2009
Status: Offline
Direct Link To This Post Topic: DRAWING TRACE.
    Posted: 17.Sep.2009 at 22:30
HI,
I'M HAVING A PROBLEM WITH MY DRWGS., BEFORE WHEN I MOVED, ROTATE A DRWG. OR DIM, AUTOCAD ALAWAYS SHOWS A KIND OF TRACE OR SHADOW SHOWING ME WHERE THE DRAWING WILL BE LOCATED, AND NOW I DON'T KNOW WHAT I DID BUT IT DOESN'T HAVE THIS FEATURE ANYMORE WHICH IS VERY HELPFUL, BECAUSE I DON'T HAVE TO GUESS WHERE THE DRAWING WILL BE LOCATED IF FOR EXAMPLE I TRY TO ROTATE IT, COULD YOU PLEASE GIVE ME A LITTLE PUSH TO GET THIS BACK.
TXS
Ferna
Back to Top
krish_architect View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 18.Sep.2009 at 12:30
at such problems.....I guess u had turned off by mistake the 'snap' or 'osnap' tab or both. Else the 'otrack' tab also could hv been switched off by mistake.....these buttons will be found at the lower middle portion of ur Auto CAD windows......click on those buttons and u will find ur tracking positions precisely......any probs again ask me
Edited by krish_architect - 18.Sep.2009 at 12:31
Back to Top
Groupie
Groupie
Using: 2009
Status: Offline
Direct Link To This Post Posted: 18.Sep.2009 at 15:54
TXS FOR YOUR FEEDBACK, BUT THIS IS NO THE PROBLEM BASICALLY, BECAUSE THE OSNAP IS ON AND THE OTRACK IS ON AS WELL, THE THING IS EVERYTIME I MOVE OR ROTATE  THE DRWG. OR DIM, IT WILL REFLECT LIKE A TRANSPARENCY INDICATING ME WHERE I'M GOING AT THE TIME I'M MOVING OR ROTATING WITHOUT DELETE THE ORIGINAL DRAWING OR DIMENSION, THAT IS VERY CONVENIENCE BECAUSE IF I CHANGE MY MIND TO LOCATE THE DRAWING IN A DIFFERENT SPOT, THIS FEATURE WILL WORK PERFECT FOR ME. REALLY APPRECIATE YOUR INPUT IN THIS LITTLE PROBLEM.
Ferna
Back to Top
Groupie
Groupie
Using: 2009
Status: Offline
Direct Link To This Post Posted: 18.Sep.2009 at 16:40
I forgot to tell you, when you are dimensioning manually this feature will shows the dim. number before you press trhe last click to fix the dim.
Ferna
Back to Top
Groupie
Groupie
Using: 2009
Status: Offline
Direct Link To This Post Posted: 21.Sep.2009 at 14:04
Ferna
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 23.Sep.2009 at 04:50
Sorry.....as I couldn't able to be on line for few days....okk yup...I hv under stood....I think the feature is known as...'Fast Silhouettes' and it has been turned off automatically as ur comp is unable to show such features (though I don't know ur comp config.) coz of graphic limitatins....if it permits the graphic req. then plz chk the following steps.....by the way in nxt reply can u tel me which version r u workin on? okk the steps are as followed......
1. In cad interface type 'Options'---press 'entr'
2. Select the 'Display' Tab.....
3. Go to the 'Display Performance' zone......
4. U will find an option.....'Draw Tue silhouettes for solids and surfaces' .......
5. Give a tick....
hope that will solve ur probs.....
if not....
plz...remind me again...no probs at all..........
Back to Top
Groupie
Groupie
Using: 2009
Status: Offline
Direct Link To This Post Posted: 23.Sep.2009 at 15:20
No, that one is not the one unfortunately, I don't know what i did that feature just turn off and is not working anymore, i've been researching but nothing coming up, if you can give me a push with it i really appreciate, txs.
Ferna
Back to Top
nameci View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 24.Sep.2009 at 01:37
Hi Ferna,
Try turning on Polar instead of Ortho.
Hope that helps,
nameci
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 25.Sep.2009 at 07:16
Sorry....as I could not do that.....is nameci's one is working... I don't know abt wht exactly it is solving.....besides if that works...its fine...then it will be the smallest solution u were lookin for...
otherwise we r trying to solve ur probs....stay tuned...
Back to Top
p3.1416l View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 25.Sep.2009 at 16:44
Hi everybody.
I think your problem will be fixed if you set DRAGMODE 2. You can set it 0, 1 and 2, as seen on AutoCAD Help.
Hope it works. Please, keep me informed
Less is more
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,225 seconds.
