RSS discussions
Discussion Discussion forum
Topic ClosedMaximise Viewport in paperspace
 Post Reply Post Reply
Author
craigie View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Maximise Viewport in paperspace
    Posted: 18.Feb.2010 at 17:21
Hi
First time on forum
using AutoCAD 2008
when in paperspace, you can see the printable area boundary as a dashed line.  You can then create a Viewport within this space to print to scale anything from model space.
Is there a way to make the Viewport the exact same size as the paper boundary without using guess work - currently i just drag the viewport size as close to the printable area as possible
thanks in advance.
craig
Back to Top
CarlB View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 18.Feb.2010 at 18:46
Don't know about that direction-
but you can go the reverse route: set up an exact area /window you want to print, then in plot manager set your print limits to match.  Your dotted "print window" will shift to meet specified area, so they will thereafter appear coincident.
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 18.Feb.2010 at 20:07
Thanks for that - will give it a try
Craig
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,210 seconds.
