RSS discussions
Discussion Discussion forum
Topic ClosedHeat exchanger flange placement
 Post Reply Post Reply
Author
Castor63 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Heat exchanger flange placement
    Posted: 10.Mar.2010 at 00:07
If you have 2 shells welded together can you still place a flange over the seam or is there going to be issues down the road.
(ilovecad- your comments arent needed here)
Back to Top
Tankman View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 10.Mar.2010 at 11:38
This is a weldment, steel. I wouldn't worry 'bout a flange welded over a seam if the flange location is required.
Will the flange have blind tapped holes to connect flanged pipe? Or, will the flange be raised to allow for the use of bolts?
Weld away!
Tankman
"When the well's dry, we'll all know the value of water."
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 10.Mar.2010 at 14:31
Its a raised face long weldneck so there is plenty of room for bolts!! Thanks for the info
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 10.Mar.2010 at 14:53
Good, raised face and long weldneck.
Post your drawing in CAD Blocks, Piping>Tanks, so we can take a peek-a-boo at your work. If you like.  Wink
Where are you posting from?
What CAD program, release, are you using?
Edited by Tankman - 10.Mar.2010 at 14:56
Tankman
Back to Top
MattMurphy View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 10.Mar.2010 at 15:18
3D AutoCAD Pipework -
Hercule Design
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,094 seconds.
