RSS discussions
Discussion Discussion forum
Topic ClosedPDF to DWG converter
 Post Reply Post Reply
Author
milenvd View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: PDF to DWG converter
    Posted: 31.Mar.2010 at 15:32
Hello,
I’d like to purchase a PDF to DWG converter but there are so many different applications out there – I do not know which one to choose.
Could you please recommend any?
What should I look for?
Could you please share your experience in PDF to DWG conversion?
Thank you for your help and comments in advance!
Back to Top
Tankman View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 31.Mar.2010 at 16:07
I use an old version of pdf2cad.
A free trial is available online for much newer versions.
Try www.pdf2cad.com for more information.
Tankman
"When the well's dry, we'll all know the value of water."
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 31.Mar.2010 at 16:47
Are the lines and the text editable after the conversion?
Thank you!
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 31.Mar.2010 at 16:58
Edit anything however, if the *.pdf was created from within AutoCAD great!
You will have to scale the new *.dxf drawing, save to *.dwg and start cleaning your drawing.
Conversions aren't great but, a great help when in a pinch!
I wouldn't survive without a *.pdf to *.dxf, save to *.dwg and I'm off to the races. An excellent tool which you will appreciate having.
Tankman
Back to Top
tulip3D View Drop Down
Senior Member
Senior Member
Using: AutoCAD2011, Inventor2011
Status: Offline
Direct Link To This Post Posted: 31.Mar.2010 at 21:29
I would say get adobe. Then you have full access to add multiple pages, jpegs, word docs, ect. Or, if all you need is to make a pdf and be done, you can get freeware from many different companys and do like tankman said. The idea of pdf is once you make it you aint supposed to edit it...changing the dwg then reprinting to pdf is easier than converting back and forth, in my opinion.
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 31.Mar.2010 at 21:31
oh wait, pdf to dwg? thats tricky man. gotta resize, all that. and its usually pixilated and not exact. Just re-draw the pdf! fun fun! lol
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 31.Mar.2010 at 21:45
Fun, oh wow! Pdf to dxf, to dwg, a tough call but, does work.
I often use the conversion when time pressed, works. Yes, drawing over is frequent.
Re-doin' text often but, again, the conversion'll get you going in a pinch.
Tankman
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,090 seconds.
