Over 1.132.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
WinKen
Newbie
Topic: menusPosted: 17.Apr.2010 at 22:52 |
Thanks for the reply --- I'll take a look at the tutorial.
The old Symbols menu tab allowed me to directly pick an item by size, view (top, side, end), determine the x & y scales, rotation and insertion point in one command.
To attempt the same thing using blocks has always required guessing what AutoCAD decided to call the item, what code they used for the view and then stretching it to length and rotation in additional commands.
But then ----- maybe I'm just set in my ways.
Cad64
Senior Member
Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 17.Apr.2010 at 22:43 |
I don't know anything about Acad Mechanical or how the mechanical symbols menu worked in 2005, but the symbols are just blocks that are saved in a folder somewhere on your machine, right? So couldn't you just create a new Tool Palette and put them all in there? This would allow you to drag and drop them into your drawings.
Here's a tutorial: http://autodesk.blogs.com/between_the_lines/2004/09/autocad_tool_pa.html I have one "Master" file where I keep all of my most used blocks. I then copy and paste these blocks into a Tool Palette so I have easy access to them whenever I need them. And yes, Autodesk retires it's older programs every year, which means no more support. I believe they just retired 2007 this year. |
Online Portfolio: http://www.rdeweese.com/
WinKen
Newbie
Posted: 17.Apr.2010 at 21:06 |
Anyone out there succesfully loaded a mechanical symbols menu into AutoCAD 2008 or newer? What I'd like to use is the Autodesk Symbols mechlt95.mnu (or the modified version I used in Lt2000i and Lt2005) as I find it easier to insert items.
The pull-down menu in Lt2005 is far faster for me to use than the method that comes with Lt2008 ........ and I suspect, the newer versions.
I use the Symbols menu for structural steel, fasteners and weld symbols.
AutoDesk bailed on support several years back ---
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,118 seconds.
menus
Topic Options
