Over 1.132.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
pete1
Newbie
Joined: 13.Jan.2008 Location: United Kingdom Status: Offline Points: 2 |
Topic: spot programmePosted: 13.Jan.2008 at 22:38 |
Hi,
i wonder if anyone can help me with this. i use auto cad 2006 to make drawings of office furniture which are mainly in 2D plan view giving measurements for c.n.c. machines to cut out different shapes of desks. to give dimensions on the dwg. i use a lisp programme called Spot. it is very easy to use and neat and tidy allowing you put many dimensions on a dwg. without it becoming too busy and cluttered . the trouble is that now i have a new computer which runs on Vista instead of XP i cannot get the spot programme to work in 2006. any solutions to this would be gratefully received . |
peter
Vladimir Michl
Moderator Group
Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2188 |
Posted: 13.Jan.2008 at 23:32 |
AutoCAD 2006 is not compatible with Windows Vista - you will need at least version 2007 with sp2.
Vladimir Michl (moderator)
pete1
Newbie
Posted: 14.Jan.2008 at 08:08 |
you can run Autcad 2006 in Vista
you right click the short cut on your desktop and under properties click check the button that says to run the programme as administrator and near the top the is a button that allows you to run the prog. as XP service pack 2. |
peter
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,152 seconds.
spot programme
Topic Options
