Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
mash166
Newbie
Joined: 09.Dec.2008 Location: India Using: autocad2012 Status: Offline Points: 1 |
Topic: 3D ModellingPosted: 08.Jul.2010 at 09:01 |
I am very much tired working on Autocad 2010 for 3D modelling.
I don't know how to reduce the file size.
Can anyone help me out?
Cad64
Senior Member
Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 09.Jul.2010 at 01:16 |
How large is the filesize right now? I would start by running PURGE and then AUDIT. Delete layer filters and layer states.
You might also want to think about whether you can break the drawing up into pieces and then Xref them into your main drawing.
Blocks are also a good way to reduce file size. If you have a lot of repetitive features, make blocks.
Online Portfolio: http://www.rdeweese.com/
clockworkc5
Newbie
Joined: 24.Jun.2010 Location: United States Using: cad mep 2010, revit 2010 Status: Offline Points: 13 |
Posted: 09.Jul.2010 at 14:32 |
file size is small. already purged and audited. ill check the layer filters, but i try to use the least amount of layers that makes sense for the project.
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,127 seconds.
3D Modelling
Topic Options
