RSS discussions
Discussion Discussion forum
Topic ClosedMaterial Properties Editor
 Post Reply Post Reply
Author
Jericho View Drop Down
Newbie
Newbie
Using: AutoCAD2009
Status: Offline
Direct Link To This Post Topic: Material Properties Editor
    Posted: 15.Oct.2010 at 10:34
Hello to everyone Smile,
I'm a new member of this forum. I'm still using AutoCAD 2009. I would like to know how to edit Materials Properities in Tool Palettes, which when I applied to an object will clearly see (very visible) such as wood grains, tiling of bricks, etc.
Hope anyone can help me...Big%20smile
Thanks
Back to Top
Cad64 View Drop Down
Senior Member
Senior Member
Using: Autocad 2011, 3DS Max 2011, Photoshop CS5
Status: Offline
Direct Link To This Post Posted: 23.Oct.2010 at 17:42
Drag the material from the tool palette and either drop it onto your model or drop it directly into the Materials Editor. From the editor, you can modify the material properties.
Online Portfolio: http://www.rdeweese.com/
Back to Top
Newbie
Newbie
Using: AutoCAD2009
Status: Offline
Direct Link To This Post Posted: 27.Oct.2010 at 09:06
Sir CAD64,
Thanks for the reply. I tried it. But still the modified material properties is not visible. For example. bricks size is 100mm x 200mm tiling. I need to magnify the object in order to see the tiling effect of the bricks. If I'm using 1:100 scale, what should I do in modifying the material properties in order to make visible in 3D or even in 2D views? Please help. Thanks.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,133 seconds.
