RSS discussions
Discussion Discussion forum
Topic ClosedFatal error
 Post Reply Post Reply
Author
obah View Drop Down
Newbie
Newbie
Using: AUTOCAD2009
Status: Offline
Direct Link To This Post Topic: Fatal error
    Posted: 11.Nov.2010 at 10:20
Please someone should help i just installed autocad 2009 each time i try to do anything on it, it ll pop up fatal error unhandled access violation writing
Back to Top
Cad64 View Drop Down
Senior Member
Senior Member
Using: Autocad 2011, 3DS Max 2011, Photoshop CS5
Status: Offline
Direct Link To This Post Posted: 11.Nov.2010 at 14:08
Does your computer meet the minimum system requirements in order to run Autocad?
http://autodesk.blogs.com/between_the_lines/2008/02/autocad-2009-sy.html
Online Portfolio: http://www.rdeweese.com/
Back to Top
obah View Drop Down
Newbie
Newbie
Using: AUTOCAD2009
Status: Offline
Direct Link To This Post Posted: 14.Nov.2010 at 23:50
Please what is the system requirement for autocad? cos i use vista with 1G RAM.
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 15.Nov.2010 at 02:39
I already gave you the link for the minimum system requirements in my previous post. But I can tell you right now, 1GB RAM is not enough to run Autocad on Vista.
Back to Top
obah View Drop Down
Newbie
Newbie
Using: AUTOCAD2009
Status: Offline
Direct Link To This Post Posted: 15.Nov.2010 at 18:12
Thanks, i visited the link but i posted my reply b4 visiting it, nevertheless thanks.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,609 seconds.
