RSS discussions
Discussion Discussion forum
Topic Closedisometric
 Post Reply Post Reply
Author
chris fong View Drop Down
Newbie
Newbie
Using: AutoCAD 2009
Status: Offline
Direct Link To This Post Topic: isometric
    Posted: 13.Dec.2010 at 14:55
Can you rotate a 2D block in an isometric drawing?
To create the isometric angle.
Back to Top
tulip3D View Drop Down
Senior Member
Senior Member
Using: AutoCAD2011, Inventor2011
Status: Offline
Direct Link To This Post Posted: 13.Dec.2010 at 15:00
'Isometric drawing'?
Your either drawing in 2D or 3.
'Isometric' simply implies the viewing angle.
You can rotate in 3D, a 2D block using the '3drotate' command.
Back to Top
HAWDesigner View Drop Down
Senior Member
Senior Member
Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010
Status: Offline
Direct Link To This Post Posted: 13.Dec.2010 at 16:10
Or, you can press & hold the Shift Key while pressing and holding your mouse wheel. This will allow you to move your mouse around and give you the dynamic view that you want. This way you're not stuck with the standard views provided by the program.
Enjoy!
R. Williams
AutoCAD 2010 Certified Professional
<!-- If all else fails hit F1 -->
<<AutoCAD 2009
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,082 seconds.
