RSS discussions
Discussion Discussion forum
Topic ClosedAutoCAD 2011 Win7 64 bit
 Post Reply Post Reply
Author
RobWil View Drop Down
Newbie
Newbie
Using: Inventor 2011 Suite
Status: Offline
Direct Link To This Post Topic: AutoCAD 2011 Win7 64 bit
    Posted: 25.Jan.2011 at 11:50
I have a problem when I still wants to work with a calcompdrawingboard III. The problem is that AutoCAD 2011 64 bit will not work with the WinTab ADI 4.2 driver. Win 7 recognize calcomps latest driver but AutoCAD will not. It´s working good on a 32 bit XP pro workstation. Can anyone help me with this.Cry
RW
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.Feb.2011 at 11:26
Is it because it is a 16-bit driver?
What version of Win7 are you using?  Home Premium?  Pro?  Ultimate?  Other?
Edited by John Connor - 02.Feb.2011 at 12:12
<<AutoCAD 2015>>
Back to Top
webgain View Drop Down
Newbie
Newbie
Using: AutoCAD2011
Status: Offline
Direct Link To This Post Posted: 07.Feb.2011 at 07:22
Autocad11 is not properly work with win7 64 bit. I am also having lots of problem while using cad.
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 07.Feb.2011 at 07:37
AutoCAD R11 might not work well with Win7 64-bit but RobWil is asking about AutoCAD 2011. This version is fully compatible with Windows 7 64-bit.
To RobWil: Make sure that also your hardware is compatible with Win7 64bit. Get the Win7 driver for your digitizer or try a general Windows driver (multi-vendor driver).
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 07.Feb.2011 at 12:18
Please clarify what version of AutoCAD you are running for us.  Is it really Release 11 or 2011?
I could fully understand you having problems if you were running r11.  There should be no problems running 2011 on a Win7 64-bit system unless something was botched during the install process.
What kinds of problems are you having?  Please be as specific/detailed as you can.  The more information we have the better your chances of getting an answer.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD2011
Status: Offline
Direct Link To This Post Posted: 21.Feb.2011 at 06:55
I am using autocad 2011 version. Problem is now resolved. the problem with the installing process. I need to reinstall it and got it resolved.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,223 seconds.
