Over 1.132.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
Page 12> |
| Author | |
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Topic: printing to scalePosted: 17.Feb.2011 at 17:47 |
The OP can always resort to pressing the Clean Screen button for wiping everything. |
<<AutoCAD 2015>> |
HAWDesigner
Senior Member
Joined: 04.Aug.2008 Location: United States Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010 Status: Offline Points: 310 |
Posted: 17.Feb.2011 at 17:36 |
I see now that the 'toolbar' the OP was referring to is called the "Drawing Status Bar" and it consists of two primary groups (the Annotation Icons and the Tray Icons). But even though everything is 'turned off', the bar remains.
Anyways, thank you for the tip on the TRAYICONS command. ![]() Edited by HAWDesigner - 17.Feb.2011 at 17:36 |
R. Williams AutoCAD 2010 Certified Professional <!-- If all else fails hit F1 --> <<AutoCAD 2009 |
John Connor
Senior Member
Posted: 17.Feb.2011 at 17:19 |
I thought the OP just wanted to rid his system tray of that one item. You want to kill the entire tray? TRAYICONS - Set it to zero. Problem solved. Edited by John Connor - 17.Feb.2011 at 17:21 |
<<AutoCAD 2015>> |
HAWDesigner
Senior Member
Posted: 17.Feb.2011 at 16:51 |
LOL...no, actually, I was hoping you would step me through actually disabling (or hiding) that Annotative Scales area. I truly can't figure out how.
EDIT: It's obvious that you can "hide" (uncheck) those 3 features, but that does not remove the entire area from the screen. Edited by HAWDesigner - 17.Feb.2011 at 16:52 |
John Connor
Senior Member
Posted: 17.Feb.2011 at 12:02 |
Semantics. You say "hide" and I say "disable". Either way, it is possible to make the Annotation Scales feature, in the system tray, not visible. There, is that better?
<<AutoCAD 2015>> |
HAWDesigner
Senior Member
Posted: 17.Feb.2011 at 00:12 |
Enlighten us o great Jedi Master.
Oops... wrong movie. ![]() |
John Connor
Senior Member
Posted: 16.Feb.2011 at 19:28 |
If he is talking about Annotation Scales, in the system tray, then that too can be disabled.
<<AutoCAD 2015>> |
HAWDesigner
Senior Member
Posted: 16.Feb.2011 at 15:15 |
I think he's actually talking about the Annotation Scales.
![]() That 'toolbar' really isn't a toolbar and I haven't found a way to turn it off completely. All you can do is hide a few of the features (as in the image above). Good Luck!! Edited by HAWDesigner - 16.Feb.2011 at 15:18 |
John Connor
Senior Member
Posted: 16.Feb.2011 at 11:47 |
If you are talking about Viewport Scale, in your Tray, then right-click in an empty grey area and deselect Viewport Scale. On my system this is located at the very bottom of my screen BELOW the command line. If you actually have the Viewport toolbar sitting above your command line there should be a white "X" in the upper right-hand corner of the toolbat itself that will close it out. |
<<AutoCAD 2015>> |
allmostawake
Newbie
Joined: 11.Feb.2011 Location: United States Using: AuroCAD2008 Status: Offline Points: 2 |
Posted: 16.Feb.2011 at 08:37 |
Thank you very much. That is certainly the easiest way to do it. I've got a new ? for you. Just above the command line is the View port tool bar right? The one with the two sets of annotation scales.How do I turn that on and off? Thanks
Post Reply
Page 12> |
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,395 seconds.
printing to scale
Topic Options
allmostawake wrote:
