Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
Page 12> |
| Author | |
tariq
Groupie
Joined: 31.Oct.2007 Location: Oman Using: 2018 Status: Offline Points: 67 |
Topic: ImagePosted: 01.Mar.2011 at 14:15 |
How we select and delete the image while image frame off.
Tariq Mehmood
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 01.Mar.2011 at 14:27 |
I would think you couldn't.
From your AutoCAD Help file:
"Normally, when image frames are not displayed, you cannot select images. However, the IMAGECLIP command temporarily turns image frames on." Edited by John Connor - 01.Mar.2011 at 14:29 |
<<AutoCAD 2015>> |
HAWDesigner
Senior Member
Joined: 04.Aug.2008 Location: United States Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010 Status: Offline Points: 310 |
Posted: 01.Mar.2011 at 15:34 |
If you're going to delete the image, why not just turn the image frame on then delete the image?
Set IMAGEFRAME = 1 Good Luck!! |
R. Williams AutoCAD 2010 Certified Professional <!-- If all else fails hit F1 --> <<AutoCAD 2009 |
John Connor
Senior Member
Posted: 01.Mar.2011 at 15:43 |
I get the impression he doesn't want to turn the frame on for some unexplained reason.
<<AutoCAD 2015>> |
Cad64
Senior Member
Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 01.Mar.2011 at 16:02 |
Unless this image is a duplicate that you just want to get rid of, you don't want to delete it. That won't get rid of it. You want to Detach it. Open your Image Manager, select the image and click the "Detach" button.
Online Portfolio: http://www.rdeweese.com/
tariq
Groupie
Posted: 03.Mar.2011 at 06:55 |
i apply the image frame command but image still not select.
Tariq Mehmood
John Connor
Senior Member
Posted: 03.Mar.2011 at 11:47 |
Is the image part of an Xref?
<<AutoCAD 2015>> |
HAWDesigner
Senior Member
Posted: 03.Mar.2011 at 14:06 |
Or part of a block, maybe?
Cad64
Senior Member
Posted: 03.Mar.2011 at 15:40 |
Or maybe it's an OLE object?
Try OLEFRAME and set it to 1 or 2. |
joewaianae
Newbie
Joined: 03.Mar.2011 Location: United States Using: autocad2007, Civil 3d Status: Offline Points: 2 |
Posted: 03.Mar.2011 at 16:26 |
Hit Ctrl all, and it will highlight EVERYTHING, then hold Shift key and window everything but the Image frame that is selected. Obviously this will not be the way to go if this is a dwg with alot of data.
JEROME LORENZO
10+ years experience drafting |
Post Reply
Page 12> |
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,185 seconds.
Topic Options
