Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
Page 12> |
| Author | |
degoos
Newbie
Joined: 07.Mar.2011 Location: Belgium Using: AutoCAD2010 Status: Offline Points: 12 |
Topic: form planesPosted: 07.Mar.2011 at 14:34 |
HI
i've made a surface using loft, but when i tried thicken, it says that it can't be executed because it intersects itself.. is there a way to avoid this? i tried to take the edges of what should be my thickened surface, but when i draw the lines so they form the contour of the surface, there is just a bunch of lines and no surface is actually formed.. when i try to draw a simple triangle on the xy plane, the same happens, i see the contours, but no plane is formed can somebody help me? thank you very much! grtz, niels
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 07.Mar.2011 at 15:50 |
Could you post the drawing so we could take a look at it?
What version of AutoCAD are you using by the way?
<<AutoCAD 2015>> |
degoos
Newbie
Posted: 07.Mar.2011 at 16:21 |
http://img98.imageshack.us/i/probleemke.jpg/
as you can see I managed to thicken it by reducing the thickness i wanted to have, on the front of the pic you can see the contours I was talking about, the upper edge is the curve of the surface i wanted to thicken, the lower edge is the same curve copied, but adapted so both upper and lower curve meet on the right side, on the left side i've drawn a vertical line, to create a closed surface, but no surface is formed... thanks for your help, niels
degoos
Newbie
Posted: 07.Mar.2011 at 16:22 |
and I'm using autocad 2010
John Connor
Senior Member
Posted: 07.Mar.2011 at 16:38 |
Unfortunately the website is blocked by our IT department's Internet policy.
<<AutoCAD 2015>> |
HAWDesigner
Senior Member
Joined: 04.Aug.2008 Location: United States Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010 Status: Offline Points: 310 |
Posted: 07.Mar.2011 at 16:49 |
This help, John? I don't have time to reply now, or I would.
R. Williams AutoCAD 2010 Certified Professional <!-- If all else fails hit F1 --> <<AutoCAD 2009 |
degoos
Newbie
Posted: 08.Mar.2011 at 09:21 |
@hawdesigner:I can't see the image you've posted, i don't know about you john? i want to try to upload it myself, but i don't know how i have to do that, it needs an url, so i have to upload it to the internet anyway?
John Connor
Senior Member
Posted: 08.Mar.2011 at 11:52 |
I do not see an image either HAWD.
Degoos: Upload your image here at the CADforum so everyone has easy access to it.
<<AutoCAD 2015>> |
degoos
Newbie
Posted: 08.Mar.2011 at 12:42 |
@John: I would like to upload an image, but when I press the insert image button, it asks for an url, so I have to insert an internetadress there i guess?
and when i do so with the link I've allready posted here, it says "error in inserting object in current location".... but the problem with forming planes is solved, when I extrude or sweep a line like you said, i can form planes now. I thought that when you draw a rectangle, the surface bounded by the rectangle is automatically formed like in sketchup, but i guess autocad doesn't automatically do this or hasn't a command to fill a boundary? I still don't know how to avoid the intersection problem in the thicken command, but there probably isn't a way? thanks for the help! niels
John Connor
Senior Member
Posted: 08.Mar.2011 at 12:50 |
You avoid the problem by creating good geometry. Just because AutoCAD will let you intersect a polyline with itself in 2D doesn't mean it will allow you to turn it into a 3D solid, surface or mesh.
When a line is extruded it is referred to as a surface.
I for one would not expect AutoCAD, created by AutoDesk, to perform in the same fashion as SketchUp, created by Google. Why would anyone assume the two programs would behave in the same manner. That would be like expecting a Mac to perform like a PC. Not in my universe.
Re: uploading images. This website does not make it easy but I do not recall being asked to provide an URL. Edited by John Connor - 08.Mar.2011 at 12:52 |
<<AutoCAD 2015>> |
Post Reply
Page 12> |
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,291 seconds.
form planes
Topic Options
