RSS discussions
Discussion Discussion forum
Topic ClosedRotating around a point
 Post Reply Post Reply
Author
vincenzoo View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Rotating around a point
    Posted: 17.Mar.2008 at 15:06
Hello you all.
I've got a little problem on autocad.
i have to rotate an object, in this example a triangle.
i can usually rotate the object around the point where i click, but now i want that do it AND the tip of triangle must go in the correct position.
see the image to understand.
A should coincide with B.
Sorry for my uncorrect English!Smile
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 17.Mar.2008 at 15:57
Either try the Reference option of the ROTATE command, or the ALIGN command.
Vladimir Michl (moderator)
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 17.Mar.2008 at 18:19
Yes! it works fine!
thank you very much Vladimir!
ByeWink
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,081 seconds.
