Over 1.127.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
heinsite
Senior Member
Joined: 05.Feb.2009 Location: United States Using: AutoCAD 2014 Status: Offline Points: 640 |
Topic: AutoCAD Intallation/UninstallationPosted: 13.Apr.2011 at 07:40 |
This feels like a stupid question, but I have to ask it anyway. For years I've been running AutoCAD on my computers on a subscription basis. And each year I get a new DVD with the new program on disk marked "UPGRADE". Naturally, over time I've accumulated several years worth of "old" versions of the program.
So here's the question: Can I safely Uninstall all those "old" versions of AutoCAD without messing up my most current (in this case, 2012) version, and recover some hard drive space?
I'm going to trust the wisdom of the group here. :)
Thanks!
Dave.
Dave Hein, P.E.
Hawaii District Engineer Kona International Airport AutoCAD Certified Professional Autodesk Expert Elite |
Vladimir Michl
Moderator Group
Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2180 |
Posted: 13.Apr.2011 at 07:44 |
Yes, you can. The old versions are not neccessary.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 13.Apr.2011 at 11:58 |
Dave:
As a form of "insurance" create a Restore Point first before uninstalling a program. If something were to go awry during the process you could restore your system to its previous state. Remove programs via the Windows Control Panel. Do not do it manually. |
<<AutoCAD 2015>> |
enigmainside
Newbie
Joined: 17.Apr.2011 Location: Pakistan Using: 2010 Status: Offline Points: 1 |
Posted: 18.Apr.2011 at 03:44 |
when installing Autocad 2011 on 32 bit windows 7, I get following error message when I run as administrator:
Following files are not found: C:\Users\ADMINI~1\AppData\Local\Temp\_A13297.tmp\setup.pkg/s P: Media\second run\ language en-us I am sick tired of trying so many times for installing 2010 and 2011 for last five days. Kindly anyone pls help me sort out the issue?
enigmainside
John Connor
Senior Member
Posted: 18.Apr.2011 at 12:03 |
Where did you get your software?
<<AutoCAD 2015>> |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,094 seconds.
Topic Options
