RSS discussions
Discussion Discussion forum
Topic Closedimport .fbk file help
 Post Reply Post Reply
Author
cadman33619 View Drop Down
Groupie
Groupie
Using: civil 2011 3d
Status: Offline
Direct Link To This Post Topic: import .fbk file help
    Posted: 18.May.2011 at 16:06
Hi,
i'm trying to learn how to import a field book file (.fbk)...i keep running into roadblocks. i have the .fbk file saved on my desktop. using the IMPORT SURVEY DATA - SPECIFY DATABASE option, i have no existing database shown and when i try to "create new survey database " and enter a name of a folder i get "the survey database does not exists and could not be created"
can someone explain how to get the .fbk file into autocad?
using civil 3d 2011
thanks
cadman
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.May.2011 at 17:08
Did you follow the instructions in your User's Guide for importing a field book file?  There's even a tutorial exercise named "Importing Field Coded Survey Data".
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 18.May.2011 at 17:48
SURE DID...FOLLOWED STEP BY STEP BUT THEN I GET TO THE STEP WHERE I HAVE TO EITHER CHOOSE AN EXISTING DATABASE OR CREATE A NEW DATABASE...AND SINCE I DONT HAVE AN EXISTING DATABASE (AT LEASTE I DONT THINK I DO) I HAVE TO CREATE ONE. BUT WHEN I TRY TO SPECIFY A NAME FOR THE FOLDER IT GIVES ME THAT ERROR MESSAGE.
CADMAN
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.May.2011 at 19:08
Either you have an existing database or you don't.  Why wouldn't you know that?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 18.May.2011 at 20:41
i'm not even sure what a database is....this is my first time trying to import field book data. i have the .fbk file but i dont know how to get in into cad. the tutorial isnt working for me.
cadman
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.May.2011 at 23:14
Try posting your question at the Civil 3D forum here:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/bd-p/66
You can also do a search of the forum.  I suggest using the words "field book".
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,227 seconds.
