Over 1.132.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
Koukou_lee
Newbie
Joined: 04.Oct.2011 Location: Greece Using: AutoCAD 2007 Status: Offline Points: 3 |
Topic: internal error - new layoutPosted: 04.Oct.2011 at 01:23 |
I get this message INTERNAL ERROR: !U:\global\src\ObjectDbx\DB\IMP\src\dbsymblk.cpp@502: eInvalidIndex when I try to make a new layout in autocad 2000/2002. what should I do to resolve the problem. In autocad 2006 and later there is no error but unfortunately is important to continue working in autocad 2002 format.
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 04.Oct.2011 at 11:54 |
Have you tried running the REPAIR option?
<<AutoCAD 2015>> |
Koukou_lee
Newbie
Posted: 09.Oct.2011 at 00:15 |
Yes I reinstalled autocad. I also tried to open the file in different pc. The file is quite big (100mb) and I think I mess it when I deleted some of my custom layouts.
John Connor
Senior Member
Posted: 09.Oct.2011 at 12:35 |
If you corrupted your file so badly you can't open it and you continue to get this error then in all probability the file is "toast".
Have you attempted to open the file on another computer running AutoCAD? |
<<AutoCAD 2015>> |
Cad64
Senior Member
Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 09.Oct.2011 at 20:09 |
Your CAD file is 100mb??? For future projects, perhaps you could utilize blocks and xrefs to help keep the file size down.
You said you can open the file in 2006, right? If so, run an AUDIT to find and fix errors and then save back to 2000 format? |
Online Portfolio: http://www.rdeweese.com/
Koukou_lee
Newbie
Posted: 11.Oct.2011 at 00:34 |
Unfortunately I tried in autocad 2007:
a) audit and purge and fixed errors and deleted the unnecessary, b) i tried copying the whole drawing-little by little layer by layer to a new one, c) I also converted dwg to dxf to dwg, but nothing made it work when i saved it in autocad 2002 at least for more than 2minutes before a new internal error appears. The file works fine -at least for now- in autocad 2006 and later, but my boss wants it for cost reasons to make it work in 2002 format... The problems is that I can't make a new layout without an internal error. Cad64 it is a drawing that is being worked for more than 5 years by the ''Water Company'' in order to create a concetrated map of an area of more than 5000sq meters... It has more than 161000 blocks, half of them include attributes, and 65000 lines and polylines. Sure, xref would work fine for the future. But the current old personnel still draws with pens and stencils... |
John Connor
Senior Member
Posted: 12.Oct.2011 at 00:50 |
If the drawing works fine in 2006 but not in 2002 maybe it is not a problem with the drawing per se. Have you tried to REPAIR 2002? That is NOT the same as doing an uninstall/reinstall.
<<AutoCAD 2015>> |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,224 seconds.
Topic Options
