RSS discussions
Discussion Discussion forum
Topic ClosedSubscript
 Post Reply Post Reply
Author
alieneye View Drop Down
Newbie
Newbie
Using: inventer 2011
Status: Offline
Direct Link To This Post Topic: Subscript
    Posted: 21.Oct.2011 at 12:44
Hi Everyone.
I want to know how do I place a subscript in the mtext command, I know on the symbols tab there is a subscript of (two) but how do I  place other numbers on the subscript? please assist.
Ta mike...
Edited by alieneye - 21.Oct.2011 at 12:46
ta-mike
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 21.Oct.2011 at 13:16
Found this at DotSoft.  I tried it and it works.
"How can I do subscript/superscript text?
There is no way to do it in standard TEXT.  However you can do it in MTEXT using the stack mechanism.  As an example bring up the MTEXT editor dialog and paste in something like:
Raise to the 3rd^   Power!
Basically the formula is to use the ^ carat symbol along with the same number of spaces as you have characters to shift up/down.  In my example above I would enter this into the MTEXT editor dialog box, there are three spaces after the ^, two to balance the shift of the 'rd' and a third for the natural space between the words.  In the MTEXT editor I would highlight the 5 characters "rd^ ", then press the A/B stacking button in the dialog. The 'rd' then becomes superscript.  To achieve subscript simply reverse the order putting the spaces and carat first, for example " ^rd"."
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,161 seconds.
