Over 1.132.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
philippe JOSEPH
Senior Member
Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1530 |
Topic: 5/8-11 UNC 2A length?Posted: 05.Jan.2012 at 07:58 |
Dave, thanks a lot !!!
Your answer is too good for me comming from THE engineer of Hawaii ( just this makes me dreamming !! )
I found my contribution to this exellent forum normal as I'm already learning a lot every day ( and I'm using AutoCAD every day at work since AutoCAD R13 - 1995 ).
Without answering at every discussion I read all of them and learn a lot.
heinsite
Senior Member
Joined: 05.Feb.2009 Location: United States Using: AutoCAD 2014 Status: Offline Points: 640 |
Posted: 05.Jan.2012 at 07:06 |
This is what really is best about this particular discussion board... what one might call the "Value-Added Posts". Folks here don't just answer the immediate question at hand, they anticipate and provide that extra measure of useful information.
Great answer, Philippe! ![]() Dave |
Dave Hein, P.E.
Hawaii District Engineer Kona International Airport AutoCAD Certified Professional Autodesk Expert Elite |
griartejm
Newbie
Joined: 11.Feb.2011 Location: Philippines Using: AutoCAD2011 Status: Offline Points: 13 |
Posted: 02.Jan.2012 at 11:35 |
thank you very much dude,yes please can you send me the sample ur talking about? ( griartemichael@yahoo.com.ph )
quick question, can i specify the length of the thread in American Standard? for example:
5/8-11 UNC 2A 6" Length
What would be the proper representation for it if i want to include the length?
Thanks!
Thanks!
Thanks! Really helpful! Edited by griartejm - 03.Jan.2012 at 01:42 |
Balot Penoy!
philippe JOSEPH
Senior Member
Posted: 02.Jan.2012 at 11:20 |
Hello, the bolt that you are talking with the "callout" 5/8-11 UNC 2A doesn't include the length.
5/8 means the diameter of 5/8 x 25.4 = 15.875 mm
11 means 11 threads per inch # 25.4/11 = 2.3090909... mm pitch
UN means UNified ( american standard )
C means Coarse ( standard big pitch versus Fine pitch )
2A means the tolerance of the fabrication ( standard )
The length of a 5/8 screw ( bolt = screw + nut ) is between 1" ( 25.4 mm ) and 6" ( 152.4 mm ) including :
1" , 1"-1/8 , 1"-1/4 , 1"-3/8 , 1"-1/2 , 1"-3/4 , 2" , 2"-1/4 , 2"-1/2 , 2"-3/4 , 3" , 3"-1/4 , 3"-1/2 , 3"-3/4 , 4" , 4"-1/2 , 5" , 5"-1/2 , 6"
You should also specify the material for example : Steel - Grade 5
You should also specify the "state fo delivery" ( protection )
Ask for more; you should read more informations about Unified Thred Standard on WIKIPEDIA or on school books if available for you.
I have an old example in PDF form of "CLARK Equipment" bolts standards that I can send to you on request.
griartejm
Newbie
Posted: 02.Jan.2012 at 10:43 |
Can you determine the length of a bolt with a callout 5/8-11 UNC 2A ?
im used to determine bolt call outs in metric, im getting confused on using American Standard Call out on threads. Help please! Thanks!
Balot Penoy!
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,145 seconds.
Topic Options
