RSS discussions
Discussion Discussion forum
Topic ClosedAutoCad LT 2010 Layers Disappeared!
 Post Reply Post Reply
Author
MikeLV2012 View Drop Down
Newbie
Newbie
Using: AutoCAD LT 2010
Status: Offline
Direct Link To This Post Topic: AutoCad LT 2010 Layers Disappeared!
    Posted: 29.Feb.2012 at 20:06
I opened my AutoCad LT 2010 today and there are no layers except the 0 (zero) layer!  I opened Layer Properties and made sure there were no filters (it's on All), and the only layer existing is the 0 (zero) layer!  How did this happen and what can I do to fix it?
Edited by MikeLV2012 - 29.Feb.2012 at 20:07
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 29.Feb.2012 at 23:04
Did you purge it yesterday?
It's going to take more information from you to figure out what happened.  Tell us what the file is, what you've been doing with it... more than likely it's something you did.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 01.Mar.2012 at 11:07
Mike:
Was this a drawing you were previously working on and had created additional layers?
Or....
Are you referring to a new drawing in which you used a custom template and the layers you created now appear to be gone?
<<AutoCAD 2015>>
Back to Top
SugarCAD View Drop Down
Newbie
Newbie
Using: AutoCAD 2011
Status: Offline
Direct Link To This Post Posted: 01.Mar.2012 at 23:26
If you created a template and saved as .dwt, did you set the path in Options>Files>Template Settings>Default Template File Name for QNEW?
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,145 seconds.
