RSS discussions
Discussion Discussion forum
Topic Closedangle override
 Post Reply Post Reply
Author
keyan87 View Drop Down
Newbie
Newbie
Using: autocad
Status: Offline
Direct Link To This Post Topic: angle override
    Posted: 13.Mar.2012 at 11:55
hi all,
i have a problem in line.. if i make any inclined line 30 degree then we need no pick the point in acad.. but my pickpoint and angle is overlapping... not get correct angle.
karthikeyan
Back to Top
Mafields View Drop Down
Newbie
Newbie
Using: Autocad2012, Google skecthup
Status: Offline
Direct Link To This Post Posted: 13.Mar.2012 at 12:18
if u know how long is line u can use this lenght , angle like 100,90 makes 100mm long line to angle 90
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 13.Mar.2012 at 17:08
Are you trying to draw a line at a specific length and angle that would be input at the command line?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: autocad
Status: Offline
Direct Link To This Post Posted: 14.Mar.2012 at 05:50
yes
karthikeyan
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Posted: 14.Mar.2012 at 07:43
Hello, if you want to draw a line length 100 with an angle of 50° from the horizontal you have to type :
Command "line", clic, @100<50.
@ will allow you drawing from any point in your space.
You can find any answer for your basic questions in "F1" ( the help ) or in the PDF files loaded in your C disk ( C\rogram files\Autodesk or AutoCAD\AutoCAD XXXX\Setup\Docs ).
Ask for more...
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 14.Mar.2012 at 23:35
Philippe has you covered... one additional note I'll add is that the default direction for zero degrees in AutoCAD is due east.  90 degrees is north, 180 degrees west, and 270 degrees south.  You can change that if you want, most of us probably don't.  Angles increase counter clockwise, so keep this in mind anytime you draw a line using the
Line @distance<angle  ex. LINE @100<45d13'12" (or) @100<45.22000
method.
Dave.
Edited by heinsite - 14.Mar.2012 at 23:36
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 15.Mar.2012 at 07:39
And you can even change the angles direction clockwise or anti clokwise in the "DDUNITS" panel + values of the angles ( Deg/min/sec or decimal degrees or grades or radians or geodesic units ).
You can also change the values of the distances ( arch. or decimal or fractionary or ing. or scient. ).
The direction for the basic angle is to set in "Direction" etc...
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,070 seconds.
