Over 1.127.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
ldconcad
Newbie
Joined: 26.Mar.2012 Location: United States Using: Autocad 2005 Status: Offline Points: 1 |
Topic: English to French language conversionPosted: 26.Mar.2012 at 21:47 |
I work for a Mechanical/Electrical Engineering firm in the US. We use AutoCad 2005. Is there any way to convert English to French text using this version? If not, does anyone know where to find French autocad symbols related to mechanical engineering?
Vladimir Michl
Moderator Group
Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2180 |
Posted: 26.Mar.2012 at 23:03 |
You can try the internal command AMLANGCONV - see http://www.cadforum.cz/cadforum/qaID.asp?tip=5961 (in Czech). Or you can use TRANS utility.
Vladimir Michl (moderator)
ARKANCE - https://arkance.world - Autodesk Platinum Partner |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,172 seconds.
Topic Options
