RSS discussions
Discussion Discussion forum
Topic ClosedChange Block AttributeText Style Globally
 Post Reply Post Reply
Author
gsksun4 View Drop Down
Newbie
Newbie
Using: AutoCad 2014LT
Status: Offline
Direct Link To This Post Topic: Change Block AttributeText Style Globally
    Posted: 30.Oct.2012 at 15:23
New to the forum.
Is it possible to change the existing text style of block attributes globally in an AutoCad drawing? So far I can only change one at a time by doing attribute edit or AT at the command line.
Thanks in advance for any help.
Glenn
Edited by gsksun4 - 30.Oct.2012 at 20:10
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Posted: 30.Oct.2012 at 15:34
Hello, if you type STYLE you will have access at the standard text style for all the drawing.
I have not tried with texts in blocks because I don't use text in blocks.
Please let us know about your experimentations....
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 30.Oct.2012 at 15:41
I have changed the style in the TEXT STYLE window and now it's set to ROMANS, however that does not change the style of the text in the block I want to change. This block appears many times in the drawing. I opened the block editor and brought up the block and tried to change with the properties palette within the block editor, but there is no style on the palette.
I'm using AutoCad 2009 LT and I know there are limitations in Lite.
Thank you for the quick response.
Glenn
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,102 seconds.
