RSS discussions
Discussion Discussion forum
Topic ClosedHelp me with this drawing
 Post Reply Post Reply Page  12>
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: Help me with this drawing
    Posted: 10.Dec.2012 at 11:54
Your only other option would be to digitize the image which is a form of electronic tracing.  This assumes that 1) you have a digitizer and 2) Draftsight supports using a digitizer.
<<AutoCAD 2015>>
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 10.Dec.2012 at 00:59
I use a lot of scanned as built (record) drawings, so my first steps are always the same.  First, I very carefully rotate a long horizontal or vertical line in the scan so that Ortho mode is useful.  Even if it's only a minor amount it's useful.  You can do this easily by drawing an ortho line and then another using the scan.  Check the angle, and if it's any measurable amount, rotate the fully drawing accordingly.
Once the rotation is satisfactory I will then scale the scan correctly.  You need a known length for this, but once you have one the process is fairly simple.
At this point I would start with the horizontals and verticals.  Since this these are airfoil shapes you may just have to do the best you can fitting arcs and splines.  But if the original is at all accurate you should be able to get very close.
Have fun!
Dave.
Edited by heinsite - 10.Dec.2012 at 01:01
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
crosswinds View Drop Down
Newbie
Newbie
Using: DraftSight
Status: Offline
Direct Link To This Post Posted: 10.Dec.2012 at 00:33
Originally posted by heinsite heinsite wrote:
If it were my project I would take it to a professional reprographics shop and have the drawings scanned.  Then I'd overlay those in a new drawing file, rotate and scale them properly, and trace very carefully.  For me this would be much more accurate than a grid repro process.  A digitizer would be ideal... but who even has one large enough for a project like this anymore?
Dave.
Thank you for your answer.
Actually i did have (some) success with the grid-method, but its very time consuming and not extrmely accurate as you say.
What method would you recomend to trace inside the CAD program once it have been scanned?
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 09.Dec.2012 at 07:35
Dave.
Dave Hein, P.E.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 09.Dec.2012 at 00:50
I don't have an example.  The last time I used a grid to transfer a design was back in high school.
Create a grid on tracing paper.  Use 1x1 or 2x2 squares.  Tape it to your profile.  Everywhere the profile intersects the grid take measurements.
Create a grid in AutoCAD of the same size.  Transfer the measurements to this grid.  Mark the intersections with a point (node).   Now connect all the nodes with lines.  Some of the lines you'll want to change to polylines and join together so you can curve fit them or create a spline.
OR....
Take a digital photo then bring the photo into AutoCAD using the ImageAttach command.  Trace over the image.  Take a known measurement and use it to scale the resultant electronic tracing so it matches the wing profile.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: DraftSight
Status: Offline
Direct Link To This Post Posted: 08.Dec.2012 at 19:44
Originally posted by John Connor John Connor wrote:
Grid pattern for reproducing art.  Same technique would apply.
http://www.draw-n-paint.com/Grids/Drawing.Grids.html
Thank you for your help.
But im still puzzled by this.
Trying to figure out how i would do it by the grid method. Just cant get it.
Do you have any example on how to do this?
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 07.Dec.2012 at 00:14
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 07.Dec.2012 at 00:08
Grid method: Tracing paper.  Put a grid out it.  Lay it over the part you want to reproduce.  Take measurements.  Transfer to CAD.
Scanning will produce a raster image.  Doesn't DS have a feature where one can import or attach an image?  Look it up in the Help file or in the user's guide.
Another option.  Do you know anyone who has a digitizing board?  They could "digitize" (i.e. - electronically trace) the image into a CAD program like AutoCAD.
Edited by John Connor - 07.Dec.2012 at 00:09
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: DraftSight
Status: Offline
Direct Link To This Post Posted: 06.Dec.2012 at 20:47
Do it by the grid method and transfer the measurements to CAD.
Another option would be to have it scanned, bring the image into Draftsight and trace over it.  You would have to have at least one dimensioned line as a reference for accurate scaling.
Do you know anything about manual drafting?  Some tracing paper and a beam compass could help in figuring things out.
Those curves could be arcs and/or splines.
Thank you very much for your help!
Im a bit unsure of what the grid method is about, tried to google it but was not lucky.
The scanning option may be the best option maybe? Do i need to make it to a vector file before importing it to draftsight, or does draftsight have a function for this?
Any more tips on that?
Best regards
Daniel
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Dec.2012 at 00:42
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 2,922 seconds.
