RSS discussions
Discussion Discussion forum
Topic ClosedRead only / write protection
 Post Reply Post Reply
Author
Alan Reed View Drop Down
Newbie
Newbie
Using: AutoCAD LT2016
Status: Offline
Direct Link To This Post Topic: Read only / write protection
    Posted: 03.Jan.2013 at 16:07
Due to a computer failure I have had to reinstall Autocad LT2013 on a new computer and I obtained the activation code. However when I open a drawing (installed onto the new computer C:drive) I keep getting 'this file is read only' even after unchecking the relevant box in drawing properties. I have attempted to copy the information into a new file but no luck, 'this file is write protected.
Any help to remove this problem would be greatly appreciated.
Regards
Alan
Alan Reed
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 04.Jan.2013 at 11:33
If you are working off a network one possible cause is a timing conflict involving your server.
Where are you attempting to save your DWG files to?  What is the full path?
Edited by John Connor - 04.Jan.2013 at 11:35
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 04.Jan.2013 at 12:22
Thanks John.
I am working from a stand alone system.
I have solved one problem by changing the Administrator settings and this then allows me access to the drawing files. But still have a problem with templates. The files are all on my internal hard drive.
Regards
Alan
Alan Reed
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 04.Jan.2013 at 14:54
What is the problem with your templates?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,199 seconds.
