Over 1.132.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
idiosyn85
Newbie
Joined: 28.Jul.2008 Location: United Kingdom Using: AutoCAD 2008, AutoCAD 2010, Inventor 2009 Status: Offline Points: 13 |
Topic: Batch PlottingPosted: 29.Jul.2008 at 18:46 |
Hello.
I'm in need of being able to plot large numbers of large dwg files, preferably in the background, whilst I'm free to get on with other things.
I can easily batch plot dwfs, so a way in which to batch convert to dwf would also be a viable solution.
I've spent a little bit of time looking for one but thought for once I might try this way of finding out instead.
Cheers
PepaR
Senior Member
Joined: 09.Jul.2008 Location: Czech Republic Status: Offline Points: 149 |
Posted: 29.Jul.2008 at 22:03 |
For DWG is 2 ways, use program Govert's GoPlot Classic for batch print PLT files or use Sheet Set Manager (standard tool of AutoCAD) for batch print on all printers, what you want.
PepaR
idiosyn85
Newbie
Posted: 30.Jul.2008 at 13:22 |
Great cheers. Sheet set manager sounds good. I don't want to have to trouble IT to get them to install a new program if possible. You say it's a standard feature of AutoCAD? I use AutoCAD 2009 in a classic layout. Cheers
PepaR
Senior Member
Posted: 30.Jul.2008 at 13:49 |
Yes, I'm sure, Sheet Set manager is part of AutoCAD.
Edited by PepaR - 30.Jul.2008 at 13:50 |
PepaR
Vladimir Michl
Moderator Group
Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2188 |
Posted: 30.Jul.2008 at 14:42 |
Sheet Set Manager may be too complicated if you need just background plotting. The standard PUBLISH command will do the same job. You can use to to plot or DWF-publish multiple DWG drawings with multiple layouts.
Vladimir Michl (moderator)
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,152 seconds.
Batch Plotting
Topic Options
