RSS discussions
Discussion Discussion forum
Topic ClosedUnexpected Problems
 Post Reply Post Reply
Author
thinker View Drop Down
Groupie
Groupie
Using: AutoCAD2024
Status: Offline
Direct Link To This Post Topic: Unexpected Problems
    Posted: 12.Aug.2013 at 09:29
These problems came from subcantractor
whenever I open a drawing the fill mode set to OFF, zoom factor value set to 12, mbuttonpan value set to 0,
when fill mode set to OFF I cannot see hatches and poly line thickness, for printing when fill mode set to ON and I print the drawing using plot command it is ok but if I use publish command then there is no hatches or line thickness in hard copy.
the other two problems are related to use of mouse wheel
How can I solve these problems?
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 12.Aug.2013 at 10:28
FILLMODE is a system variable that is saved WITH the drawing.  Reset this value the way you want it and save the drawing.  The next time you open that drawing it will have the mode you want.
ZOOMFACTOR and MBUTTONPAN are both system variables that store their values in the registry.  When you set them the way you want they will retain those values for all drawings until you reset them.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
Groupie
Groupie
Using: AutoCAD2024
Status: Offline
Direct Link To This Post Posted: 12.Aug.2013 at 15:59
Dave.
Thank you for reply, once I save drawing with required settings and reopen the drawing it return to first values
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 12.Aug.2013 at 16:25
Are you in the habit of loading custom lisp routines upon every instance of opening a drawing?  That's the only way I could see the values being overridden.
<<AutoCAD 2015>>
Back to Top
wajidgates View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 23.Dec.2013 at 09:07
Hi,
I am facing the same issue. Any solution?
Thank YOu
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Dec.2013 at 11:46
heinsite provided an answer wajidgates.  Have you followed his advice?
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 27.Dec.2013 at 10:39
And that's my story and I'm sticking to it.  LOL
Happy Holidays, All!
Dave
Dave Hein, P.E.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,146 seconds.
