Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
spettro4
Newbie
Joined: 25.Nov.2012 Location: Saudi Arabia Using: AutoCAD Status: Offline Points: 4 |
Topic: Too many lines after sweeping...Posted: 23.Aug.2013 at 10:57 |
uploads/324645/Too_many_lines_after_sweeping.pdf
Hi, I just experienced this (see attached pdf) after making a 3D pipe elbow. There are too many lines (circles) after sweeping. this is seen when iam in 2D wireframe and in Xray. But the excess lines (circles) are not seen in realistic visual style. How do i fix my 2D wireframe and Xray visual style?
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 23.Aug.2013 at 15:56 |
While in 2Dwireframe visual style are you able to select any of those lines and erase them?
I thought you meant the three that exist below your elbow. But you might be talking about the isolines? Edited by John Connor - 23.Aug.2013 at 16:26 |
<<AutoCAD 2015>> |
philippe JOSEPH
Senior Member
Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1538 |
Posted: 23.Aug.2013 at 16:17 |
Hello Spettro4, if you want to see more or less lines set your variable ISOLINES ( 4 by deffault, set it to 0 and you will see no lies other than 2 circles, set it to more up to 2047 to see more lines.
This is for the "object space"; if you want to print anything else than 2Dwireframe then you will have to "open a viewport" in the "paper space" and set it properly so that it will be : realistic, conceptual, shaded, etc... with the options in the command MVIEW.
Play also with DISPSILH ( display silhouette ).
Ask for more and tell us if this helped or not.
spettro4
Newbie
Posted: 24.Aug.2013 at 04:08 |
Philippe Joseph,
thank you. I set the isolines to 0 and the dispsilh to 1. the excess lines disappeared.
spettro4
Newbie
Posted: 24.Aug.2013 at 04:11 |
John,
Thank you for the reply. I couldn't erase the excess lines (apparently they are isolines) during 2d wireframe (or x ray). I got a tip from Philippe Joseph, so i set the isolines to 0 and the dispsilh to 1. This made the excess lines disappear. Regard.
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,199 seconds.
Topic Options
