RSS discussions
Discussion Discussion forum
Topic Closedarrowheads
 Post Reply Post Reply Page  12>
Author
jsanderson View Drop Down
Newbie
Newbie
Using: autocad2013
Status: Offline
Direct Link To This Post Topic: arrowheads
    Posted: 27.Aug.2013 at 17:16
I'm new to the whole forum discussion thing so pardon my slip ups. I had a question about scaling all of the dimension arrowheads on a saved drawing. I did not draw the original, but I have to make some changes to it. I'm pretty sure that there is a way to change all of the arrowheads at once but I cant find out how to do it. so I am stuck changing all of them individually. if anyone can point me in the right direction it would be very appreciated!
thank you
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 27.Aug.2013 at 18:03
Change the size of the arrowheads globally via the Dimension Style command (DimStyle).
Dimstyle > Modify > Symbols and Arrows tab.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: autocad2013
Status: Offline
Direct Link To This Post Posted: 27.Aug.2013 at 19:00
im pretty sure that only works for when you are starting a new drawing. I think for the ones that are set in a saved drawing you go about it the same way but then you have to select the styles in use and then modify them with the way that you have mentioned but getting it applied to the drawing is where I get stuck.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 27.Aug.2013 at 19:56
Change the arrow size in your dimension style then use the UPDATE option for dimensions to make the changes in your drawing.
Edited by John Connor - 27.Aug.2013 at 20:12
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: autocad2013
Status: Offline
Direct Link To This Post Posted: 27.Aug.2013 at 20:59
I see the problem! you CAN change them all together by going threw the steps that we talked about and  using the update option BUT the dimensions can NOT be exploded! in this case, all of the ones that I mentioned are exploded so...........im screwed!
Back to Top
Newbie
Newbie
Using: autocad2013
Status: Offline
Direct Link To This Post Posted: 27.Aug.2013 at 21:00
thank you very much for pointing me into the right direction. I appreciate the help!
Back to Top
Newbie
Newbie
Using: autocad2013
Status: Offline
Direct Link To This Post Posted: 27.Aug.2013 at 21:15
john conner,
do you deal with autocad a lot? do you know much about drawing isometrics? I have a couple questions about that stuff also.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 28.Aug.2013 at 00:07
Maybe you should have mentioned that right up front?
In the future give us as much information as possible as it will go a long way towards helping us to help you.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 28.Aug.2013 at 00:08
john conner,
I have a fair amount of experience with AutoCAD including working on both 2D and 3D isometric piping drawings.
I'll be away for a few days so other forum members will have to assist you with any questions you may have regarding isometrics.  Good luck.
Edited by John Connor - 28.Aug.2013 at 12:05
<<AutoCAD 2015>>
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 28.Aug.2013 at 14:38
"...in this case, all of the ones that I mentioned are exploded so...........im screwed!"
Not necessarily -- are the resulting independent arrowheads Blocks?  A routine could easily be built that would find all Blocks of a given name, and give them all any scale factor you like.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,254 seconds.
