RSS discussions
Discussion Discussion forum
Topic Closedbreak
 Post Reply Post Reply Page  12>
Author
pytha View Drop Down
Groupie
Groupie
Using: autocad2013
Status: Offline
Direct Link To This Post Topic: break
    Posted: 18.Dec.2013 at 11:19
Multiple lines break at the same time is that possible
help
bart
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.Dec.2013 at 11:21
In theory....yes.
We need more detail though and an image would help too.  Words tend to fail what an image can convey.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.Dec.2013 at 12:00
Well????????????????????  We're waiting.
<<AutoCAD 2015>>
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 18.Dec.2013 at 14:59
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 18.Dec.2013 at 15:09
If you are looking for breaking lines at all intersections, you can use the tip:
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Groupie
Groupie
Using: autocad2013
Status: Offline
Direct Link To This Post Posted: 21.Dec.2013 at 10:36
I need parts drawing on the floor (FLOOR PLOT) these parts must be milled from slabs. These lines must fall within the plates. Useful if you can say breaklines outer plate
tanks
bart
Back to Top
Groupie
Groupie
Using: autocad2013
Status: Offline
Direct Link To This Post Posted: 21.Dec.2013 at 10:42
I'm looking for a routine that will select a line, then that line will be broken at points where it intersect other lines.
Or better, to draw a line which will break when intersect with other lines.
bart
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 21.Dec.2013 at 12:59
Did you test any of the lisp routines previously mentioned?
I am pretty sure I have seen a custom lisp routine that will break all lines at intersections with other lines.  I don't recall however if the routines creates a gap or not.
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: autocad2013
Status: Offline
Direct Link To This Post Posted: 21.Dec.2013 at 13:09
Which lips routines do you mean? Is there a possibility to send me a link?
Rgds,
Bart
bart
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 21.Dec.2013 at 17:46
Did you click on any of the links provided by Kent Cooper or Vladimir?  There were four in total.  Yes or no?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,090 seconds.
