RSS discussions
Discussion Discussion forum
Topic ClosedText
 Post Reply Post Reply Page  12>
Author
kc13 View Drop Down
Groupie
Groupie
Using: Autocad 2024
Status: Offline
Direct Link To This Post Topic: Text
    Posted: 21.Dec.2013 at 23:32
Hi All hope everyone is well,
I have drawn some house plans no problems, but when i enter text in model space it appears very small at 2.5 text height.  But when i enter the text in layout tab at 2.5 text height it is ok, please help as to what i am doing wrong. Guys sorry to say it is now doing the same as it is in model space, the text when entered at 2.5 in height is appearing very small in layout as well.
Many thanks to all.
KC
Edited by kc13 - 22.Dec.2013 at 00:39
kc
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 22.Dec.2013 at 12:02
KC - I tried answering your question in the other post.  This could get confusing having more than one post with the same question.
<<AutoCAD 2015>>
Back to Top
kc13 View Drop Down
Groupie
Groupie
Using: Autocad 2024
Status: Offline
Direct Link To This Post Posted: 22.Dec.2013 at 21:50
Thanks Jhon, would it be possible if you could give me an example how to do this please.
Thanks
kc
kc
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 22.Dec.2013 at 22:27
See this is where it is going to start getting confusing as your question seems to be in reference to the answer I gave to your original question back in the other thread.  So the problem becomes....where to answer.  This thread or the other one?
My question to you is do you want your text and dimensions in model space or in your paper space layout?
<<AutoCAD 2015>>
Back to Top
kc13 View Drop Down
Groupie
Groupie
Using: Autocad 2024
Status: Offline
Direct Link To This Post Posted: 22.Dec.2013 at 23:48
Jhon i think i would like to enter text in paper space layout, if you could give an example it would be great.
Thanks
kc
kc
Back to Top
purti View Drop Down
Newbie
Newbie
Using: AutoCAD 2D, 3D 2014
Status: Offline
Direct Link To This Post Posted: 23.Dec.2013 at 09:50
hey
In layout i thing you use template as like maximum of A1 size of drawing when you will printout on A1 or A2 size paper size it will be not look so short as per paper size.
purti
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Dec.2013 at 11:43
I have no idea what the heck purti above is talking about and I suggect KC that you ignore his posted comment.
If you are going to put your text and dimensions in paper space then it should be set to a height of 2.5mm or whatever is considered standard.  The one thing you must do is be sure to make your dimensions "associative" which is not the same thing as "annotative".  Dimensions that are associative will remain associated with the objects they are dimensioning if those objects are stretched or moved.
To make dimensions associative click on the Tools drop-down menu, click on Options, at the Options dialog box click on the User Preferences tab and look at the right hand side.  Under Associative Dimensioning enable Make New Dimensions Associative.  Now you are ready to dimension in your layout.
Also make sure that you have assigned the proper scale for your viewport then LOCK the viewport so you do not accidentally change the scale.  Do you know how to do this?
Finally, make sure you use your OSnaps when you are dimensioning.  If you don't then AutoCAD will most likely think you are dimension a paper space object and return the wrong dimension.
Got all that?
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Dec.2013 at 15:53
This is a link to a simple tutorial by Ellen Finkelstein regarding annotative dimensions.
http://www.ellenfinkelstein.com/acadblog/tutorial-automate-annotation/
I'll post (separately) my own sample drawing shortly.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Dec.2013 at 16:04
When this drawing is printed the text and dimension text heights will all be the same (0.125) despite the fact that the viewport scales themselves are totally different.
If you have set up your annotative dimensions and text correctly they should also display the same in your layout.
People who have to deal with many scales in a drawing and require the ability to have dimensions/text appear or not appear in certain viewports will find annotative scaling to be an invaluable asset and should consider its use.
That said, I personally don't use annotative scaling because it really isn't necessary in my line of work.  I do all my dimensions and text in my layout to real world size.  My text and dimension heights are usually 3/32" or 1/8th".
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Dec.2013 at 16:43
Something else occurs to me re: annotative scaling.
Users will have to become familiar with the following system variables.
ANNOALLVISIBLE
ANNOAUTOSCALE
ANNOTATIVEDWG
ANNORESET
ANNOUPDATE
CANNOSCALEVALUE
SELECTIONANNODISPLAY
And maybe SCALELISTEDIT.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,439 seconds.
