  Visitors: 8818
CAD tip CAD tip # 7954:
AutoCAD 2012: Generate 2D drawing views from 3D models.
A - answer The VIEWBASE command in AutoCAD 2012 (2013,2014...) can conveniently generate 2D views (projections) of any 3D solid. This command can be run in a layout.
If the model space of the current drawing contains a 3D object, the 2D views are generated from this 3D model. If there is no 3D object in the given DWG file, the command offers view generation from external Inventor 3D models (.IPT and .IAM files). But the 3D model inside the DWG drawing can be also imported from SolidWorks, Rhino, CATIA, Pro/ENGINEER, ACIS, Parasolid, IGES, STEP, JT etc. - so you can create the drawing views also from these sources of 3D CAD models (formats).
These documentation commands create projections in the selected directions - orthographic or isometric, you can specify the display style (shaded, hidden lines, tangencial lines...). When the model is updated, the user is prompted to update the drawing views. All created view representaions can be associatively dimensioned. The resulting drawing sheet can be exported to a separate DWG file (EXPORTLAYOUT).
An example of making views from an Ainventor model can be seen in the CAD video #31:
Video
ACAD2014ACAD2012ACADM2012
4.5.2011    31655×
Prices - CAD eShop:
Tip 13800:Visually compare 3D geometry in CAD and BIM files.
Tip 13719:How to load a 2D DWG drawing of a part into Fusion 360?
Tip 13587:Dynamic label of 3D coordinates.
Tip 13082:PDF published from AutoCAD shows blurred lines.
Tip 12569:How to Explode a ViewBase generated from a 3D model?
