Over 1.097.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 11530:
Question
If you have problems starting the Print Studio utility in Windows 10, try to set its Compatibility setting to "Windows 8". Right-click on the Windows icon, choose Properties and go to the Compatibility tab.
PrintStudio
15.7.2017    8694×
Share the tip:
applies to: PrintStudio ·
Tip 14281:Mapped network drives (S:, T:, X:, etc.) are not available in my CAD application.
Tip 14134:How to increase menu font size in ReCap Pro?
Tip 13735:My initial login to Fusion 360 isn't working.
Tip 13379:Revit failing on machines with multiple graphics cards.
Tip 9331:What is contextual field and why it is not updated in a block?
Back    All CAD Tips
Categ:
