Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 7230:
Question
Internet Explorer 7 and 8 in Windows Vista and Windows 7 use by default the "Protected mode". This mode – for security reasons – isolates the internet browser session from the rest of the operating system. One of the consequences of this protection is that iProject saves the downloaded files to the virtualized folder:
C:\Users\USERNAME\AppData\Local\Microsoft\Windows\Temporary Internet Files\Virtualized\C\Users\USERNAME\Documents\
The document Open function then does not work properly and the downloaded (copied-out, checked-out) files are saved elsewhere.
There are three possible solutions:
  1. Increasing access rights for the MSIE application – run as Administrator or disable the UAC protection in Windows (not recommended)
  2. Disabling Protected mode for the "Internet" or "Local intranet" zone (if you use the local version of iProject) - not recommended
  3. Adding iProject server to the list of Trusted servers and disabling the protected mode for the trusted zone.
    Use Tools > Internet Options > Security and click on the "Trusted servers" checkmark icon and on the Servers button. Clear the https certification request (if you don't use https for iProject] and add the address of your iProject server to the list of Trusted servers. Confirm by OK, and immediately clear the checkbox "Enable protected mode" (this setting applies only to the Trusted zone). Restart Internet Explorer.
    (You can disable the top warning yellow pane by mouse right-click.)
iProject
22.2.2010    9217×
Share the tip:
applies to: iProject ·
Tip 7241:Searching text in DWG drawings (without AutoCAD).
Tip 6515:AutoPDF - Automatic publishing of PDF file on every save of the DWG drawing
Tip 5044:ActiveX component not installed when entering iProject.
Tip 4858:Some documents are not listed in my iProject folders.
Tip 4395:Quiet installation of Arkance Systems (XANADU, CAD Studio) applications.
Back    All CAD Tips
Categ:
