Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 13452:
Question
Using the freeware utility HideItem you can hide (turn off their visibility) individual elements of dynamic arrays in AutoCAD (not only the array as a whole as in HIDEOBJECTS), or individual clicked attributes in individual block references. The HideItem command hides the elements you point to. The (in)visibility stays stored in the DWG file. The dynamic nature of the array is preserved even after disabling the selected instances of the array elements.
The tool works not only for dynamic rectangular, polar and curve arrays (ARRAY), but also for other DWG object types, e.g. block attributes.
The reverse command ShowItem will again show (unhide) these hidden objects - you can select all objects (except arrays) at once, or individual dynamic arrays to be completely "revealed". For block attributes, just pick any visible part of a block - all its attributes will be re-displayed.
Download the HideItem utility from DL Download, load it into your AutoCAD with APPLOAD and run it by typing the command HideItem or ShowItem.
Using HideItem:
ACAD
26.8.2022    24398×
Share the tip:
applies to: AutoCAD ·
Tip 14454:How to hide dimensions with zero- or small length?
Tip 14392:How to get rid of the dot displayed by P&ID symbols in Plant 3D?
Tip 13694:Individual modification of elements in AutoCAD dynamic arrays.
Tip 13561:Beware of "permanently" hidden objects in DWG drawings.
Tip 12997:Hiding Revit dimensions smaller than...
Back    All CAD Tips
Categ:
LogOff 2006 More info
